Matt-and-Riley
Flight distance : 324442 ft
Ono Posted at 2017-5-17 06:55
Do you think he will turn around? My idea is not to pour into the water. Is a safety system in case it falls into the water ... I will do a safe test
I think if it falls into the water, it's 50 / 50 what way up it will land. Unless it's a complete power failure the props are probably still spinning, it's going to bounce and flip around before drowning upside down.
It will keep it floating, so you will be able to recover it and won't have to go diving for it. Will it keep it dry, I doubt it.
Remember it is quite rare for these to drop out of the sky, I know you've had a bad experience, but the chances are you'll fly for years now with no problems. Think you're planning for an event that has already happened, shutting the door after the horse has bolted. Sorry - may not translate well |
