Donnie *
Flight distance : 3636782 ft
I see what you mean now, just a bit shakey , I have seen much worse . Have you balanced the props? Be sure and also check the vibration mount for anything that could be transmitting vibration to the board ? ( the board should be just floating on those balls ) Make sure the Locks that are used for the X5 camera are in the locked position . Be sure to check the 2 flat black ribbon wires from the vibration board to the Aircraft and make sure they are not causing vibration , they can sometimes be tangled up a bit and touch the Vibration dampening board transmitting vibrations or are taught and casuing vibration by reducing the balls job of dampening .
You may need to get other balls for the vibration mount , some members move them around for the best dampening effect .
Best of luck and lovely scenery there in Holland , just beautiful !!
donnie
