Is my battery broken?
1571 10 2017-5-17
Shayd
Flight distance : 247306 ft
[size=14.6667px]I don't consider myself a pro, It's a little hot today but After charging the batteries and messing a bit with the camera settings I noticed that one cell voltage is lower than all the rest.
[size=14.6667px]
[size=14.6667px]When I turn on the engines a pull the throttle a bit up I get this:
[size=14.6667px]
[size=14.6667px]Is this a problem?
2017-5-17
RichJ53
Flight distance : 1837356 ft
It looks like the battery needed to be balanced out. Try discharging all the way down to 5% and recharge to full. This should reset the intelligent battery circuit. The deep cycle discharge sometimes takes 2 times to get things back in order.
At this point it is not bad, but keep checking for a few battery cycles.  Using DJI batteries and chargers the user does not have many options regarding balancing. We need to rely on the equipment provided
Keep us posted
Rich
2017-5-17
DJI-Jamie
Flight distance : 112405 ft
It looks like it's within OK levels, but try Rich's advice at your earliest convenience.
2017-5-18
DTK
Flight distance : 1943159 ft
I had inherited a similar battery issue from buying a used Inspire 1. Charging and discharging your battery will not help at all no matter how many times. The only solution is you open the top of the battery and charge the particular cell that is out of balance. That is the short coming of "intelligent battery".
2017-5-18
DJI-Jamie
DTK Posted at 2017-5-18 18:24
If the battery still has warranty left on it (not specified by the OP, though), opening the battery like that would void the warranty.
2017-5-18
Dobmatt
Flight distance : 1831050 ft
As for the second issue you mentioned, it's rather obvious that the system will report problem since - apparently - you start the motors in your bedroom. You didn't put the props on, did you? So, when you throttle the motors up and no resistance is detected, guess what the bird will tell you ...
2017-5-18
Shayd
Dobmatt Posted at 2017-5-18 21:25
No it's not about the error, I just needed to put stress on the battery to see the voltage drop. I'm extremely limited with flying in NYC but I'll try to discharge it and charge if that does not help. RMA
2017-5-19
Shayd
RichJ53 Posted at 2017-5-17 21:02
I did deep discharge as you mentioned, probably bit lower than 5% but It was not done trough load. The drone sat on in my room. Then recharged back to full. Now I get this. This is extremely concerning as in a month I have to film in Pittsburgh convention center above about 5,000 People (With permissions of course) and in one scene film departing cruise and I need not get some voltage alerts when over water.
2017-5-23
ronin rs211
I just had the same issue with a battery. I am waiting a week so far for DJI to send a replacement..
2017-5-24
DTK
By looking at your photo, the batteries have only been charged 8 times. It sure is under warranty.
2017-5-24
DTK
I bought mine through authorised dealer in Australia. Hope I don't have wait at all for any warranty claim. Too many horror stories here involving DJI support
2017-5-26
