daivatam
Flight distance : 473389 ft
Romania
This is the ugliness of the mavic camera...this and the spot color or vignette....they are artifacts because the poor camera compression...because bad codec and limited cpu processing power inside the drone-max bandwidth is 60 mb lower end for 4k...it is not an malfunction of your mavic...all are the same... also the sensor is extremely noisy and the inside processing it is realy bad...try neat video for noise but it will take ages for 4k and it is a paid software...to minimize this you should pan very slow, you should use an nd filter to keep the shutter speed at around 50-60 frames ideally because the motion blur will take place of ugly artifacts rendering the image more pleasing, to film at 2.7k because the same 60mb bandwidth will be used and then upscale to 4k if u want, to lower a tad sharpness in full daylight...better to stay on 0 try -1 but not in low light. The best resolve will be that the dji will implement a better camera algorithm codec/compression processing...but seems that this is just an dream because one reason or another.
