Pacifica 4K - My best Mavic Pro footage yet
12Next >
10452 48 2017-5-18
jlegit
4K @ 24FPS, D-Log, +1 Sharpness, ND16 and edited with Adobe Premiere Pro. Very happy with the way the footage turned out!
2017-5-18
Bintryin
Flight distance : 164406 ft
Love it do you think Vimeo is a higher res than You tube . Yours looks Amazing
2017-5-18
DJI-Thor
Flight distance : 13602 ft
Wow !  Really nice ,  thanks for sharing~
2017-5-18
Anoniem
Flight distance : 70043 ft
very well done. I would be happy to shoot this kind of footage to
Do see noise in footage because of sharpness +1, if you think you need it then you can use a plugin for premiere with a denoising profile for the mavic. Not a cheap solution but this seems to be mandatory with the DJI mavic.
2017-5-19
W.T. Foxtrot
Flight distance : 1316732 ft
Great shots - and thanks so much for sharing your settings.  As a newbie, I am still trying to figure out the camera settings.  SO MANY CONFLICTING VIEWS  OUT HERE!  Hard to sort through sometimes, but it really helps to know how you got there.
2017-5-19
jlegit
Bintryin Posted at 2017-5-18 23:25
Thank you! I think both Vimeo and Youtube have 4K, but I do like the way the Vimeo interface looks when playing back. Just a personal preference
2017-5-19
jlegit
DJI-Thor Posted at 2017-5-18 23:53
Thank you!!!
2017-5-19
jlegit
Anoniem Posted at 2017-5-19 00:59
Yes, there's especially some noise in the shadows because of the grade. I didn't run it through any noise reduction software, but maybe I should give Neat Video a try on this footage. +1 really helped me get a sharp image, though
2017-5-19
jlegit
W.T. Foxtrot Posted at 2017-5-19 05:25
Thank you! Happy to share - similarly I had to take some time to try out a bunch of different settings until I found something I was happy with
2017-5-19
thehippoz
Flight distance : 23 ft
Nice work, I wish could shoot like that. Nm I'm not even sure that's a mavic xd The polar pro nd filter and newer firmware dlog really that good?
2017-5-19
fans10e20992
Flight distance : 70089 ft
Could you expand a bit regarding the Plugin for Premiere Pro? Where can I get it?
2017-5-19
AG0N-Gary
Flight distance : 700846 ft
Re Vimeo vs Youtube:  Being in a somewhat limited bandwidth situation, I find Vimeo buffers differently and takes longer to do it.  Sometimes I can sit on Vimeo for a minute or so before it will start at 1080P.  Youtube doesn't take as long, but they may not be the same quality.  I don't know.  I do see comments about their compression now and then.  Nice video!!
2017-5-19
Anoniem
fans10e20992 Posted at 2017-5-19 09:46
A good start is to google with the words "Mavic denoise", look at the Footage from Breo. He is also using Neatvideo plugin together with Premiere. Within Neatvideo you can create a profile for the Mavic sensor, this makes the footage so much better. You even can correct the intra frame issue with darker detailed areas
2017-5-19
jlegit
thehippoz Posted at 2017-5-19 08:59
Haha! I'm using Taco ND and they have been working well. And I actually misspoke - I'm using D-Cinelike. D-Cinelike provides enough detail in the highlights while still giving enough color to start off with. D-Log was a bit flat for me
2017-5-19
Yogi123
Flight distance : 3194669 ft
Nice work, and thanks for sharing the settings.
2017-5-20
BillyG
This is stunning footage mate, can't say enough how much I enjoyed watching this. Seriously good edit well done.
2017-5-20
Woodwanger
Really nice to watch....good job ;-)
2017-5-20
thehippoz
jlegit Posted at 2017-5-19 23:54
Ah thanks, give it a shot.
2017-5-20
jlegit
Yogi123 Posted at 2017-5-20 01:34
Thanks! Also I mistakenly said I used D-Log - I actually used D-Cinelike, which I like more
2017-5-20
jlegit
BillyG Posted at 2017-5-20 03:59
Thanks man!!
2017-5-20
Dronaldo
Flight distance : 606601 ft
Nice!  keep it UP!
2017-5-20
fans32ed94a3
Flight distance : 78465 ft
Great work Jonathan. One of the best I have seen. I have a question. What effect makes the video actually misty?  I guess its not caused by the filter or color correction.
2017-5-20
Rodger8
Flight distance : 20145135 ft
Great job .Awesome scenery. I could shoot there every day.
2017-5-21
CheckYourSix
Where is the link to the video?
2017-5-21
garbun629
Flight distance : 6168 ft
Hi,
I'm totally new to video editing and drone.
I've seen a lot of drone videos with 21:9 (like movies...), can I select this setting in Mavic or it is post production setting?
If this is post production setting, is it called 21:9 ?
Great Video!!!
Thanks.
2017-5-21
jlegit
fans32ed94a3 Posted at 2017-5-20 16:45
That's actually how it was that morning, hazy by the ocean!
2017-5-22
jlegit
garbun629 Posted at 2017-5-21 19:38
Hi,
I just set the sequence size in Premiere to 3840x1634 for a 2.35:1 aspect ratio (for 4K footage).
2017-5-22
acejoy
Beautiful, the wave audio really adds to it as well.
2017-5-22
BIGDZ
Flight distance : 10255860 ft
I know this area pretty well, flew my P3a a couple of years ago. It's a very windy place especially the Devils Slide area. It's good to see the MP held up. Great footage!!
2017-5-22
jlegit
acejoy Posted at 2017-5-22 10:25
Yep, made it a point to spend time working on the sound. Thanks!
2017-5-22
jlegit
BIGDZ Posted at 2017-5-22 10:39
Yeah I  got very lucky this morning, there was almost no wind with great light and clear skies. Had to take advantage of the opportunity!
2017-5-22
Dave Kent
I always wanted to fly here but I didn't .It's a no-fly zone.
2017-5-22
jlegit
Dave Kent Posted at 2017-5-22 12:14
No warnings of NFZ from the DJI app, also checked Hover before taking off. Where is the NFZ?
2017-5-22
sFalcon
Nice scenery!
2017-5-22
GiantBubbleGuy
Flight distance : 41962 ft
Great job. Beautiful footage and flying. Do you know what the structure sitting on top of the eroded soil is?
2017-5-23
DJI-Jamie
Flight distance : 112405 ft
Fantastic job! Thanks for sharing. I really liked how you composed your shots.
2017-5-23
CheckYourSix
Where is the video?
2017-5-24
jlegit
GiantBubbleGuy Posted at 2017-5-23 13:52
Thanks! I believe its a bunker from WW2 days!
2017-5-24
jlegit
Weird, must be a mobile issue. Link to video is here:
2017-5-24
jdp1989
Really lovely video!
To @GiantBubbleGuy it looks a bit like an abandoned crane. That was my favourite shot, panning over the mountain.
2017-5-24
12Next >
