ManAndDrone
Flight distance : 3538297 ft
New Zealand
Craig photoman Posted at 2017-5-26 20:00
Gorgeous! Which ProRes were you using? (4444 XQ, 422 HQ) Do you get the star-like effect on the sun rays naturally from the aperture shape in the camera or is it a filter or perhaps the craggy rocks it is shining through? Thanks. Very inspiring. I just got my i2 and x5s with ProRes.
Thanks Craig.
All 4444 XQ, As it's slightly more forgiving if you underexpose, to bring back those dark levels.
Star-Light Effect comes with an f.stop number of say f10 and higher.. higher the number the more defined the burst is. It is also lens dependant so the stock 15mm will act different to the 45mm for example. Doing this may sacrifice a bit of sharpness though so bare that in mind. If the end deliverable is web it really doesn't matter.. Hope you enjoy your new kit!
