hallmark007
Flight distance : 9812789 ft
smh Posted at 2017-5-20 08:36
the warning were " tap to focus", "subject lost, unable to follow it, not able to identify it" and "unable to follow it, go closer and try again".
When i recoverd the craft, all leds were on, so still underpower. Unbelievable !
From your PH log it doesn't look like you did anything wrong, you had good signal good gps and no compass problem, but logs end very abruptly, and as lacyboy has pointed out problem with battery voltage, and I would suspect this also, but dji will make the final decision, I hope they decide in your favour.
Good luck. |
