Mark Guille
Flight distance : 2031818 ft
Jersey
Look under "Aircraft Status" scroll down to the bottom, it should be there. When you say it's not working, do you mean it is not working properly or do you mean it does nothing? It uses the sensor underneath to know how far to raise the landing gear, depending on what surface it is on, this may not work (grass and carpet it will raise the gear until the body of the aircraft hits the ground, you may need to place it on a hard surface like the case.
Mark G. |
