Waynesail
Consider this scenario: I am flying my Mavic with visual line of sight but some distance away. I glance down at the controller and discover that I no longer have image transmission. Since, as I understand it, telemetry is carried on the image signal, I therefor also no longer have distance and altitude information from the drone (is that correct?). The control signal, which is separate from the image signal, may or may not still be connected; I do not know. It could even be dropping in and out intermittently; I have no way of knowing. Thus I do not know whether the drone has switched to RTH and is on the way home. I look up, but these old eyes can no longer pick out the drone against the background. Here is my quandary: if the drone is already in RTH mode and I press the RTH button, it will stop and just hover until the battery runs out. If however, the control signaL was still connected, then it is just sitting there hovering, waiting for me to press the RTH button, and the battery will eventually run out if I do not press it. What does DJI recommend that I do in this situation? Press the RTH button on not? It seemns that there is a 50% chance that I will lose the drone which ever choice I make. Am I missing something here? I know that a low battery will eventually force it into RTH, but that is risky because a marginal battery may run out before the drone reaches home. I think that should be a last line of defense.
It would seem to me that the RTH button should NOT be a toggle, because there are situations in which the pilot may not know whether or not the drone is already in RTH mode. There needs to be some way to force the drone to RTH, no matter what it is doing. I guess turning off the controller would do that. Is that what DJI recommends?
Also, as I understand it, if I move the left stick up, that will take the Mavic out of RTH. This seems to me to be a recipe for disaster, especially for beginners who are still trying to sort through the overload of new information.
DJI Ken, I would really appreciate your input here. Thanks.
