Help with error trying to do calibration
1437 5 2017-5-21
rstekeur
Flight distance : 167477 ft
In the dji go 4 app it says I need to calibrate the avoidance sensors to increase accuracy. When I click on the calibrate button in the assitant I get an error "[size=14.6667px]Frame Alignment error" and won't go past there. Also says Please reboot aircraft which I have.
2017-5-21
Jenee 2
Flight distance : 7852129 ft
Not sure what is happening here but this video may help if you have missed something:
2017-5-21
Exib
Flight distance : 153760 ft
Did you leave the Gimball lock on when you turned on the aircraft?
What happens when you turn off the aircraft and re-start the app do you still get the same error message
2017-5-21
BobStekeur
I found out what it was, Windows 10 didn't install all the drivers correctly. After holding the shift key while booting into windows I was able to get the drivers installed and finally got the dot's to show and was able to finish the calibration.
2017-5-22
DJI-Ken
Flight distance : 1515312 ft
BobStekeur Posted at 2017-5-22 07:04
Glad you got it sorted out. There's no need to calibrate the sensors unless the app asks you too.
2017-5-22
Osee
Flight distance : 530758 ft
I spent hours trying all the fixes in this forum - i tried two different windows 10 machines and then booted to a win 8.1 and nothing worked - finally i installed win 7 on one of the hard drives ... shazam !
2017-8-24
