user45062be949
Flight distance : 60512 ft
Sweden
Hi,
I crashed my Phantom 4 from about 3-4 metres.
A prop broke and has been replaced, but other than that it both looks fine and have no problems flying..
The gimbal however is acting very wierd. When I tilt the aircraft, the gimbal both rolls and tilts the camera, same behaviour when I roll.
Also the yaw is very unstable and seems to have problems stabilizing, the slightest yaw movement makes it shake back an forth.
There is no stabilizing problems on the roll and tilt, just that the movement is not correct.
I have tried calibrating the gimbal but it doesn't help.
I have also checked for obstructions but I can see or feel any, if feels perfectly smooth to manually move the gimbal between the mechanical stops(While turned off)
Do I have to buy a new gimbal or is there some other calibration or reset I can try? Any suggestions?
All help/suggestions is greatly appreciated!
//Markus
