fans2cccf7e4
Flight distance : 6854 ft
Here is the correct answer.. DONT DO IT. Done it. crashed!
To take off a moving platform, be it cruise ship , boat whatever, you need all sensors off and to be in full atti mode.
The mavic is the worst for this kind of mission.
1 - it has no landing gear to easily grab, while the quad is tilted to keep up with the speed of ship
2- you can't actively turn off gps. ie activate ATTI mode manually.
From experience I was on a cruise ship.. it slowed to 10kts.. about 20klmh.. I was out on an open area .
Attempted take off as soon as it did pitched in the opposite direction of the ship and flew straight into a window.
Lucky the battery came lose when it crashed and cut power to blades.
Like Air crash investigations, after replaying the events, it made perfect sense.
The mavic, when it takes off, wants to lift and hover in the same spot determined by gps.
The ship is moving so the mavic is effectively travelling at 20klms per hour before props start.
As soon as it starts and lifts off the mavic registers that it is traveling at 20klm/h and tries to hit the breaks to hover as its suppose to.
it does so correctly as it suppose to but the ship keeps moving around it. so the Mavic will stop in its marked gps spot until in my case it
hit the window.
Unless you are quick to correct and push forward on the sticks you will be caught off guard.
Either way its not a good idea.
So to launch of a ship the best place is off the back. so when you take off it will hover over the water while the ship moves forward and away.
at that point you would then need to chase the ship, and make sure the home point is not set. because if the drone gets too far or u run low on batteries
it will go back to the middle of the ocean where u launched from.
Again not a good idea to launch off a moving ship.
Im glad mine crashed into the window because if I did manage to lift off after not considering the gps effects I would have had a bad experience trying to (crash) land.
I would have had to chase the ship and then try to hand land the quad. With downward sensors on and a tilt angle to match the speed of boat I recon I would have
lost a finger or 2.
so moral of the story is don't do it on a cruise ship while its moving! firstly its not allowed and the mavic has to much automation to allow this to be done safely.
One last thing if forgot to mention, the ship
is all made of steel. Metal screws with the compass.. I had compass error that was coming and going..
I had a moment of bad judgement focused on the picture moment and not my safety, i did the take off and luckily it crashed softly.
Luck was on my side and I walked away with a broken prop.
Big lesson learnt that day
So my advise to you all, if you want to launch of a moving ship.. DONT DO IT!
There are too many variables working against you when taking off.. and if you do good luck trying to land it again..
If you don't crash trying to land and don't lose fingers... go play the lottery cause you are the luckiest person on earth!
