RicardoGray
Flight distance : 4356421 ft
Just a comment on this as I also had some issues some time back with Litchi. For me, when DJI released the last firmware, I would get that RTH on missions that I had flown many times before and it would send my bird home. I struggled with it and tried to isolate the issue. I finally emailed Litchi and they suggested I look into the DJI settings for "Smart" RTH. It was of course set "on". The Go app monitors the battery levels, distance travelled, etc. , and when it think it needs to return will kick in the RTH. Toggle this option off, and your Litchi will work as it did before. Litchi told me it was embedded in the firmware and they could not control this, so even when flying missions, etc. with Litchi, if the battery level was thought to be low or whatever, it would trigger the RTH. Even though the DJI app was not running. You need to be aware that you must monitor your battery levels and distances. I turned this option "off" and have never had an issue. I hope it works for you. |
