Nees
Flight distance : 80991 ft
Belgium
There is an option to activate obstacle avoidance when RTH is initiated, not sure if you activated it or not. I think it is off by default for RTH.
You should also have set RTH much higher , just te be sure. Also, RTH is ALWAYS in a straight path. It will not fly the path you flew. For example, what if you were doing 10 circles around you, why would RTH do 10 circles again before landing? The shortest path is the best.
Sadly, it is user error for not setting height already high enough. But I understand you are now kinda mad and would blame DJI. But with your next drone, you will think: why was I stupid for not setting it high enough.
