fanscc51c021
Flight distance : 25030 ft
I am a newbie and the drone has been flying pretty good. Although it has started to act unpredictable after a flight last evening. I hit the home button on the DJI go app and the drone returned to home. When it landed the propellers started to shut off but then 2 propellers started back up then all 4 and the drone tipped over on the propellers and was running full speed. I was abel to pick it up and turn the battery off to stop the drone. I flew it for another test run and once it took off it should have hovered about 4 feet in the air but it just steadily climbed and I had a hard time getting it back to the ground. I then recharged the battery, and controller. I proceeded to do another tesdt flight after I calibrated the drone. It still is acting on its own. Not sure what tot do at this point. Does anyone have any thoughts or steps I should consider. (Also I checked the drone and it was not damaged accept 1 propeller was slightly damaged at the end. Approx. 1/16" inch.)
