N3 S-BUS problem
7821 15 2017-5-24
LONGSHOT3506
Flight distance : 18326677 ft
South Korea
Hello I have a new dji N3 flight controller
i use Aurora9 TX and Optima SL (S-BUS) RX     [tx,rx,N3 is Latest firmware]
system work well at NAZA-V2 and NAZA-Lite But N3 doesn't work
i can't fix this problem
Thank you for time sparing to read this.
2017-5-24
NORMAP
Same here. I get the same readings as you have in your green box, on the red box, it only shows the absolute maximum, no gradual change. Seems no DJI staff is commenting on this.
2017-6-24
rotormedia
Lithuania
Same here too. But with A3 Pro FC. Problem start after latest fw update. Downgrade did not help...
2017-6-25
Orpheus
Russia
Got the controller in its original factory packaging. To activate barely found the Assistant2' old version. On the latest version, the activation of the controller did not pass.
Taranis X9D + X8R receiver. On rcgroups.com some peoples write that N3 works fine with with this transmitter/receiver. I talked to one of them, checked his settings, the problems did not disappear.
My problems:
SBUS not working
Can't change battery to anything other than default 6s
Large acc0 bias
Can't enable SDK function
Gains params reset to default after power off
Can't calibrate compass and IMU
Latest N3/X8R/XJT firmwares. Latest OpenTX. Latest Assistant 2.
Any ideas?
2017-10-5
WiSi-Testpilot
Try assistant v 1.1.2, see here:
https://www.rcgroups.com/forums/ ... ad%2A%2A%2A/page150
2017-10-5
Orpheus
Russia
Thank you so much. I found the version 1.1.2, reinstalled it and it all worked. Calibrating both the IMU and the compass, changing the necessary settings, everything is saved. The receiver connected by SBUS.
2017-10-5
fansa75a31ba
Flight distance : 39728 ft
WiSi-Testpilot Posted at 2017-10-5 13:19
https://www.rcgroups.com/forums/showthread.php?2647235-Official-DJI-A3-%2A%2A%2AOwner-s-Thread%2A%2A%2A/page150
sorry, when i can download the 1.1.2 version? is it for mac or Windows? thank's
2018-1-2
fansa75a31ba
fansa75a31ba Posted at 2018-1-2 10:09
sorry, i would write where, not when...
2018-1-2
WiSi-Testpilot
Now you may use the recent version v 1.2.0 from Dec.29.
For me it works.
Best regards,
Wilhelm
https://dl.djicdn.com/downloads/ ... 81.2.0%EF%BC%89.pdf
2018-1-3
Orpheus
Russia
Windows version: https://dl.djicdn.com/downloads/ ... stant+2+1.1.2_2.exe
Mac version: https://dl.djicdn.com/downloads/ ... 216bf(b21de8d8).pkg
I'm using the Windows version. I do not know whether Mac version will work
2018-1-12
hazardPRO
Hi I know this is a old thread but im having the exact same issue.
Im using Hitec Flash 7 with sBus (optima) receiver. I get the exact same results as the person on this opening ticket.
Ive tried changing N3 firmware (made no difference) and I am using Assistant 2 v1.2.4 (I cant find anywhere to download old versions?).
Ive tried on both PC and MAC.
HELP - desperately need to get this working.
H
2018-10-18
hazardPRO
FYI seems Hitec TX/RX is not compatible.
Tried Radiolink and it works. :/
H
2018-10-23
fans2528ad72
Flight distance : 598360 ft
Hi i am having the same problem as above, i am running on FW version V 1.7.15 (i down graded ) and have tried with assistant V 1.1.2  Assistant V2 and the latest assistant but i am still having the same problem with a Futaba T10j using Sbus , it is impossible to connect the RC with the N3 even though i can see the signals working in the basic channel window where you can assign the channels
Please help
thank Craig
2019-3-7
tysonfromcanada
I had a similar problem, frsky X8R Pro and N3.  If I assign any channels other than the default and landing gear then the controller stays in failsafe after restarting.  The only way I could get it to work was:
On receiver page, switch receiver type from sbus to something else, and then back
This triggers calibration.  Do that
Channel 5 is flight mode by default on mine.  That should work already.
Assign channel for landing gear if it works for you
Leave IOC, return to home etc alone.  None of this stuff works after restart.
Power off/on and see if it still works.
That's it.  I can't get it to work any other way
2019-3-21
quadnet1
Futaba T8J won't connect the my N3 SBus  please help anyone
2019-11-2
JDanilom
Brazil
I managed to solve the problem. I was using an existing model on my radio, I created a new one and recognized the L9R receiver.
2021-1-31
