rydfree41
Flight distance : 153268 ft
ghost_ATX Posted at 2017-5-24 18:53
I switch between Litchi and DJI Go4 all the time. Never had a problem other than if you have one of the apps open you should make sure the other one is hard closed so they don't compete. I have switched between the two while my bird was hovering in the air (about 10 feet away from me - not anywhere dangerous). Opened Go4 and hard closed Litchi while hovering. I only did it because Litchi's video transmission was spotty at the time and I couldn't see what I was filming, which very rarely happens. I wouldn't recommend doing it on a regular basis, but my Mavic suffered no ill effects since the switch was quick enough before RTH kicked in. I use iOS btw. I also have AutoPilot but it's more cumbersome to learn to use so I haven't really used it.
RTH will not kick in solely due to the app being closed or losing connection . The remote controller has control over the aircraft , the app is simply an interface for more functions . |
