Mavic video blurring
2239 30 2017-5-24
fans8b5d58d2
See below link to screenshot, specifically, the trees on the right side of the frame. There is a weird blurry blending happening. Does anyone know what this is or how to fix? I am using poloar pro ND filters, and shooting manual.
http://imgur.com/a/HJCNB
2017-5-24
fans8b5d58d2
slow motion video blurred, need help.
See below screenshot for reference. I took this at 2.7 k shooting 60fps, the mavic was moving foward very slow (like 4mph). I was also using a polar pro ND filter. I can't figure out why the frame looks totally mushed and blurred / distorted. anyone know of a fix here?
http://imgur.com/a/GZWDq
2017-5-24
thehippoz
Flight distance : 23 ft
Try shooting at 0 sharp without d-log. Some like d-cinelike and art. I shoot normal with the shutter up over 100. Seen some really good footage under 100 but it's probably to do with newer firmware.
2017-5-24
thehippoz
I don't think that's off the sd? You can't even do 60 fps in 2k.
2017-5-24
Ex Machina
Flight distance : 1806362 ft
You can't shoot 60fps at anything other than 1080, do you mean you had a 1/60 shutter speed? Were you using a negative sharpness setting?
2017-5-24
Ex Machina
Using a negative sharpness style setting?
2017-5-24
Ex Machina
I guess the OP's two threads were merged into one?
2017-5-24
thehippoz
Ex Machina Posted at 2017-5-24 16:12
Aye, they merged them.
2017-5-24
fans8b5d58d2
yes, similar issue I guess. I meant to say shooting 1080p on the 60fps post. I am shooting using cinelike and I have a negative sharpness in the camera settings. doesnt seem normal. is it a camera focusing issue? or an issue with the ND filter?
2017-5-25
fans8b5d58d2
thehippoz Posted at 2017-5-24 15:54
you're right, I meant 1080p, my bad.
2017-5-25
fans8b5d58d2
Here is a link to the video render if you want to take a look (the 4k shot over the ocean - look over to the blurry trees on the right) (the boat on the left also has some weird blur going on)
https://www.dropbox.com/s/hi6web ... lyover%202.mp4?dl=0
2017-5-25
Igordur
Flight distance : 620696 ft
Yep ,it seems that I have the same problem… But This is the top left part for me !
I tried all the settings, same result ...
Photo_Floue
2017-5-25
fans8b5d58d2
Igordur Posted at 2017-5-25 07:57
Photo_Floue
yeah, I see it. not as bad though since its so far away.
2017-5-25
fans8b5d58d2
I think what I am trying to get across... these images are losing tons of detail. I am trying to figure out what the cause is... ND filters, focus or camera hardware issue.
2017-5-25
Igordur
I don't use filter.
I had not paid attention before today, It seems that all my photos are blurred in the top left… It's not the jpeg compression, same problem with raw files.
2017-5-25
thehippoz
Photo_Floue
Can see it left side. If you center focus- bind it to c1 and then check the photos. Might be a warranty claim.
2017-5-25
fans8b5d58d2
thehippoz Posted at 2017-5-25 08:48
thoughts on mine?
2017-5-25
thehippoz
The 1080 60 is a known issue already, actually anything over 30 is going to alias. And like machina said, your using a negative sharpness.
2017-5-25
Igordur
So, I'll wait for the update this week, with a little luck ...
2017-5-25
fans8b5d58d2
thehippoz Posted at 2017-5-25 09:20
using -1 in sharpness shouldn't have this dramatic of effect
2017-5-25
Ex Machina
Photo_Floue
To test whether your camera has a decentered lens, shoot against a brick wall in good light and then examine the corner areas for consistency.
2017-5-25
Ex Machina
fans8b5d58d2 Posted at 2017-5-25 07:28
It's completely normal for the Mavic's camera when you use negative sharpness.
You might be able to get away with using negative sharpness in some situations, like in very bright, evenly lit conditions, but in high-contrast and lower light situations negative sharpness is just going to turn dark areas into mush.
2017-5-25
Ex Machina
fans8b5d58d2 Posted at 2017-5-25 11:21
Shoot with sharpness at 0 and see for yourself. Some folks recommend shooting +1 sharpness in lower light to compensate for the Mavic camera stack's tendency to aggressively apply noise reduction, which appears to be the root cause of the blurring.
2017-5-25
fans8b5d58d2
Ex Machina Posted at 2017-5-25 11:36
okay, I will give it a shot. thank you for the feedback, I hope this solves the issue! Do you know if there is a fix for the 60fps"mushyness"?
2017-5-25
Ex Machina
fans8b5d58d2 Posted at 2017-5-25 11:49
60fps isn't known for mushiness but rather for introducing aliasing, the only workaround for that is to not use >30fps 1080p for any subject matter that has lots of straight lines or is susceptible to moire effects.
2017-5-25
Parkker
Flight distance : 8891 ft
Ex Machina Posted at 2017-5-25 11:27
Would you suggest an optimal distance to shoot away from brick wall? Thanks
2017-5-25
Igordur
Thank you guys, my problem is exactly this one : http://forum.dji.com/thread-87429-1-1.html
2017-5-25
Ex Machina
Parkker Posted at 2017-5-25 12:54
Enough to fill the frame, but not so close that lens distortion becomes obvious and distracting.
2017-5-25
Parkker
Here is shot taken today. I have noticed a bright area in center of images that is sharper in detail with loss around edges and looks more pronounced on left side.
Any feed back appreciated. Thanks.
https://drive.google.com/file/d/ ... IAseITBb7_VDEg/view
2017-5-25
Ex Machina
Parkker Posted at 2017-5-25 17:50
https://drive.google.com/file/d/1U5Oek0h6oXrReEeq9ZzuIAseITBb7_VDEg/view
I was going to write that the right side is blurry while the center and left edge is fine. Is the uploaded image flipped? I'd contact support.
The brighter area in the center is an artifact of the camera. It used to be a lot worse but a recent firmware update added some correction in the form of a lens profile.
2017-5-25
Parkker
Ex Machina Posted at 2017-5-25 18:27
I meant to say right side no image not flipped. Obviously right side not as crisp.
Thanks for your impressions.
2017-5-25
