DRONE-flies-YOU
Flight distance : 1450594 ft
When in SPORT Mode, 720/60p and inside 300 meters (range to Mavic) the DJI Goggles lose connection ("disconnected") repeatedly. I get Liveview back after letting go of the sticks & waiting a moment. Rinse/repeat. It rarely happens at 100m, but consistently @ around 300m. It appears to happen when flying directly away from the goggles at maximum speed. I'll notice it flicker a bit momentarily & then if I continue at max stick deflection forward, it'll disconnect. So I know it's coming, but nonetheless that should not occur (as seen in marketing videos).
Also in SPORT Mode... FAST HEAD TRACKING!! When you're in Head Tracking, switch into SPORT Mode and it'll yaw to your SPORT Mode sensitivity settings... Pretty cool!
I do NOT find it nauseating at all whilst in Smooth Mode (720/60). It's quite the experience. I ran through 2 batteries & it felt like 5 minutes!
