pijemcolu
Denmark
Beard Posted at 2017-6-7 04:31
Not exactly, with the 3D map areas the ends of each transect become the waypoints. You are still limited to 99. A waypoint is the point at where one of the flight parameters change...eg. altitude, speed, heading, take a photo, etc. So essentially, by not hovering to capture, you are traversing from one waypoint to the next....taking photos along the way. More DJI mis-represenation.
That is correct although by disabling hovering, you do get rid of a big number of waypoints. Depends on what shape you are mapping, but if you do stick to a rectangle, which might as well be the case if you are capturing big areas the waypoint limit becomes less of a problem. Not to mention the battery.
I can't fly my drone as of now, and so I am simply looking at this and browsing how to go about the waypoint limit. Did you guys try to disable hovering? How was the image quality? |
