Aircraft disconnected
1064 2 2017-5-25
HighCamera
Flight distance : 1213238 ft
I got the goggles today and am trying to use them with my P4P. I get everything all going and it's great and then I lose connection from the RC to the bird (not good when flying) I might be the only one to be trying to do this
2017-5-25
Geebax
Unfortunately, losing the video connection to the aircraft is going to happen at some stage, there is no such thing as a guaranteed connection. The issue is more about how far away the aircraft was, and under what circumstances this happened. If you lose connection, then fly back towards yourself to re-establish connection. But if this is happening only a short distance away from you, then there may be a problem with your system.
2017-5-25
HighCamera
Actually I was out on the front porch investigating settings etc. so I never flew. It happened in the house repeatedly, I started changing cables and usual troubleshooting stuff (reboots all around) then I went outside and it happened a few times. No phone or tab any where around. I have the HDMI module that I got from DJI, I wonder if that has anything to do with it?  I'm hooked up using USB to the goggles from the same usb that you would normally use to hook your phone or tablet.
Anyway... weird part is everything works for a bit. That cancels out a whole lot of suspects.
Maybe the update this weekend will help!!
2017-5-25
