DroneFlying
Flight distance : 10774613 ft
As Hallmark pointed out, we'll be in a better position to understand what happened once you upload the log from your flight. At this point, though, everything appears to have worked the way it's supposed to. The aircraft will initiate an automatic landing once the critically low battery threshold has been reached, and as adiru pointed out that the minimum threshold was reduced by DJI in a recent firmware release. As you obviously know, though, it's possible to essentially override the automatic landing and continue flying to reach a more suitable location for landing.
As far as the crash that occurred during the final landing sequence, there's a message in your screen shot indicating that obstacle avoidance was going to be disabled during the landing sequence. That message apparently appeared during the initial (automatic) landing sequence, but would have also applied to any subsequent landing. In other words, once you did allow it to start landing it would have done so without OA enabled, increasing the likelihood of some sort of collision, which is apparently what happened. |
