Donnie *
Flight distance : 3636782 ft
Did this happen immediately or have you tried to update the Aircraft ? If you did an update what version did you try to load ?
If you did an update to the Aircraft , did you also update the Transmitter as well ?
When you hear the chirping , is it because you have tried to update to the firmware on the aicraft via the SD card ? If so does it have a beat to it like this ddd -ddd ddd- ddd -ddd Or is a solid ddddddddddddddddddddddddddddd, that would indicate a failed update .
Also as Mark mentioned , do you have a good connection between the Camera /gimbal and the vibration board, be sure you are placing the Slot on the gimbal into the /tab on the vibration board FIRST, then lower the two round mating surfaces of the Camera /gimbal and vibration board being sure to Lock the two together once mated.
If you could get back to us before trying to update, ( if you already have not done so ) it maight save you some grief .
Tips for loading NEW firmware to SD card and transmitter
donnie
