DJI-Jamie
Flight distance : 112405 ft
Mikey8567 Posted at 2017-5-25 16:44
Ok I'll check out both the pad and the card as a reference. And go from there. I usually don't have an issue with PNY with other video related stuff but you never know. Thanks for the advice and time.
In addition to what Geebax provided, try the following button combinations:
Reset the RC of presets:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
I'd recommend manually relinking so that everything still communicates properly:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will beep like D-DD. This may take a few seconds of holding it.
*While holding the buttons, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
Keep us posted on how it went. |
