Lok Mavic
Flight distance : 1486660 ft
Hi, could you give use a little insight on the log? Will really appreciate it if you upload it to Airdata.
Flying above ocean is a little bit dangerous. Make sure GPS is locked. Always set the RTH to the drone take off position, use exact location is better. Fly against the wind so that when RTH is initiated in case of connection loss, the wind will help the return speed.
Signal loss can be caused by many things. Visible causes like tall buildings, trees etc are easy to avoid, but invisible causes such as interference are the one we have to be more careful with. |
