mixchief
Flight distance : 182057 ft
fans34c3bd8d Posted at 2018-2-12 14:58
it's been months since I did this - over half a year. i have to remember. so first, you have to realize that I originally shot my video in RAW format. Essentially, each video clip is a folder with DNG files inside. so for each clip, I would import the entire folder of DNG files into Lightroom, and I'd color-correct one frame, and then I'd apply that setting to the rest of the DNG files inside Lightroom. Then I'd export those DNGs as high-res JPGs to a new folder. Then In Adobe Premiere, I'd import each folder of JPGs as an IMAGE SEQUENCE, which Premiere would essentially treat as an individual video clip.
this is my result: https://vimeo.com/220985776
Forgive the inquisitive nature of this humble photographer, could you tell me two things, when you say high-res JPGs what exactly are you referring to, just export full size 100% quality JPGs, or is there another setting, and when you import to Premier (have to find pout how to do it in FCPX) as an image sequence, is that a parameter you set when importing the files? Thank you for sharing the video, it looks absolutely perfect, exactly where I want to go with my footage. |
