thehippoz
PimpDawg Posted at 2017-5-26 10:20
All true, however.....
If you don't update then your aircraft will eventually operate in a degraded state - no live video feed, short flight distance and height, etc.
If you block the app from connecting to bgcentre.com, then change the config file that GO uses to check the firmware version, should be fine. That (probably) makes the only way they could force you to upgrade, by hard coding a specific expiration date in the firmware. I doubt Dji would do that. Blocking is probably not a bad idea right now.
I run android, I finally got a verison of go and litchi that works perfect on android 6. So froze it there. I wish could run those goggles, but oh well. If had screen going black, loss of control, crashing.. Would roid rage Just want to fly and film. |
