Maxxpsoft
Flight distance : 380594 ft
fanse1af22cc Posted at 2017-5-27 22:44
It seems like you are the guy who always answers questions. Thank you.
After posting this question I found a DJI tutorial that explained the whole thing and it was basically what you said. So it would seem that my tree was the exact problem.
I was thinking that trees weren't a solid enough obstacle, like a building, but it seems that it is.
P3 standard might check. Go to settings. Click where it say P-GPS up top. If Enable Max Distance is turned on then max distance is 500 feet. Slide it to Turn it off. Now set your max Height also, US is 400 feet so set it at 120 meters
I raise it to 400 feet(max) and fly it Max Distance 3,235 ft
I got nearly 100' trees at the back of my yard about 200 feet away.
Mileage may vary depends on where you at, city a lot more interference from other wifi's on the 2.4 GHz band. I live in the country |
