Updating Stopping WiFi
731 6 2017-5-27
Aero Mavic
Singapore
I noticed most times during or after updating software/firmware, my iOS device WiFi would automatically gets disconnected. The latest update went fine, but again my WiFi gets disconnected. During previous update I even had to turn on my cell data connection instead in order that the update could get through.
Anyone experienced this? What could be the cause, and more importantly how to stop WiFi from disconnecting? I certainly don't want to use up my data plan for updating.
Thanks.
2017-5-27
laceyboy
Flight distance : 159820 ft
It could be your phone problem or your wifi bandwidth is slow.
You can try to turn off Wi-Fi Assist under Settings > Cellular on your phone.
2017-5-27
Aero Mavic
Singapore
Forgot to mention that I use iPad Pro, no cell data plan. When a WiFi got dropped, I turned on my mobile phone hotspot to connect and get update.
My home WiFi has always been very stable, except when it comes to getting dji Go updates. Read that some others have encountered this same issue too.
2017-5-27
laceyboy
So your iPad Pro is working fine with iPhone hotspot but not with your home Wi-Fi.
Conclusion, it is your home Wi-Fi problem.
2017-5-27
Aero Mavic
Singapore
As mentioned, home wifi works perfect for years, and still fine.
2017-5-28
Nees
Flight distance : 80991 ft
Belgium
If has been said so many times. Your wifi get being "killed" (not really) due to the same band used on the mavic and remote, but with a higher dB. Your modem/router in underpowerd to come above that signal. I always update on 4G.
2017-5-28
Aero Mavic
Singapore
Ok thanks Nees. That explains it.
2017-5-28
