A3 Firmware failure do to GPS Time OUt
714 1 2017-5-29
fans344b9a88
Hi. Bought the A3 a while ago and got around to connecting it. Probably the original firmware. Downloaded, first the Mac versions of Assistant Software. None of them would connect to the A3. Downloaded the latest version of the Windows version, it would connect but said I needed to update to the latest version, 1.7.0.5. Ran the update several times and it would get to 98% and stop. When I selected the trouble shooting option I received the following error message. "1a00 GPS fail when data at 15/168 Time Out." I tried several times to unplug everthing and reconnect to make sure everything was correct. Using Assistant version 1.1.1. This should not be this difficult. I wonder if I am caught up in DJI's new inititave on GPS settings?
2017-5-29
DJI-Jamie
Flight distance : 112405 ft
Have you made sure that the A3 components are installed properly? What firmware version does the A3 says is on it right now?
2017-5-31
