Matrice 600 Series - Remote Controller Channel Expansion Kit
1280 8 2017-5-31
ckk.post
Denmark
Can you use it with lightbride 2 on an  diy x8
To trigger camera
2017-5-31
DJI-Jamie
Flight distance : 112405 ft
What flight controller do you plan to use with the DIY rig? It should work, but it would depend on the set up.
2017-5-31
ckk.post
Denmark
DJI-Jamie Posted at 2017-5-31 19:57
A3 Pro with hobbywing pro esc and  tiger u5 motor gimbal diy
2017-5-31
DJI-Jamie
ckk.post Posted at 2017-5-31 20:59
Based on what's provided, it should work when you have the A3, LB2 and channel expansion kit.
2017-5-31
ckk.post
Denmark
DJI-Jamie Posted at 2017-5-31 21:10
Thank you very much for your reply
2017-6-1
ckk.post
Denmark
Just one more question
can  you still monitor the batteries life even if it is not from dji
Her i think i on how many percent there is left
can you do that
2017-6-1
DJI-Jamie
ckk.post Posted at 2017-6-1 09:48
It's not able to keep track of the precentage, however, it does keep track of the voltage you would set up the battery warnings based on the voltage readings.
2017-6-1
ckk.post
Denmark
DJI-Jamie Posted at 2017-6-1 12:03
Ok thanks for that
2017-6-1
DJI-Jamie
No problem, best of luck to you.
2017-6-1
