Mad_Angler1
Flight distance : 2741657 ft
The M600 uses the A3 as standard with custom FW, what you can add is the IMU kits for redundancy turning it into the A3 Pro setup
As standard the A3 uses its internal IMU with in the FC, Adding 2 Pro Kits will give you 2 external IMU's, 2 additional compasses and 2 additional GPS for redundancy switching.
In theory its not going to bring much addition stability other than its likely it will default to one external IMU over the internal one but it will give much more redundancy in a failure situation.
If your looking to real stability you need to be looking at the RTK with the Pro Kit. |
