DJI-Jamie
Flight distance : 112405 ft
I would concur with DTK. Also, I want to emphasize that you should have your RTH height set high enough to clear the buildings should interference or signal loss occur, which is very likely in a high rise situation. Worse case, you may want to have it set to hover so that you can get into better position to regain control accordingly. |
