export .dat file for GPS data Matrice 600 Pro
3330 2 2017-6-1
DimiC
Flight distance : 26073 ft
Belgium
Hi everyone
I'm desperately trying to access the .dat files on my Matrice 600 Pro.
Would like to use this file to geotag my pictures (from my Sony A7RII)
According to the latest firmware update, the A3 will even save the GPS data of the waypoints at which the camera gets triggered when using DJI GS pro.
I tried to access the files using 2 different ways:
1. Using DJI Assistant 2. : You can select to start "SD Card mode". I suppose normally I can then access the Matrice file system? But when activating this option almost nothing happens. The options in DJI Assistant get limited, but I can do nothing to get to the .dat file.
2. Using DJI GO app: You can select to export the aircraft data. When doing this, I get the message to connect my aircraft to USB. Which I do of course. But still nothing happens.
Does someone knows the correct way to get to the .dat files?
Thanks!
Dimitri
2017-6-1
hemanthd95
1) Power on your remote controller2) Power on your flight battery
3) connect the usb cable from DJI to your laptop
4) open DJI assistant 2
5) You should see two tabs (M600 Pro and Lightbridge)
6) enter M600 Pro
7) Go to data, enter sd card mode
8) You should see a file explorer screen with all the available flight logs.
Note: When you enter sd card mode, you will lose your connection with DJI assistant 2
2021-10-18
djiuser_eqLkq8XsIBSZ
hemanthd95 Posted at 2021-10-18 06:41
Hello, I've done the above steps and converted the .dat file into a .csv using DatCon. However, I'm unsure where the rtk corrected coordinates are in this file. I used CTRL+F to search the .csv for "RTK" and get many blank columns. They columns are "RTKdataate", "RTKdata:Time", etc.
Does this mean there was no RTK data collected? Or it wasn't sent to the drone?
2022-4-7
