AACY
Flight distance : 518012 ft
This is very normal, that's why is always good to check your props after each flight, you might had sustained some damage on the leading edges of the blades. This can cause the props to become unbalanced and generate non-desired vibrations not to mention that it will also lose some of it's lifting capacity meaning that the motor will have to spin faster to achieve the same amount of lift. Normally I use as a rule, that if an indentation is bigger than 1mm either on width or depth, change the prop.
Cheers! |
