ACW
Flight distance : 13877205 ft
Article 241 - endangering safety of any person or property
A person must not recklessly or negligently cause or permit an aircraft to endanger
Article 94 - small unmanned aircraft
(1) A person must not cause or permit any article or animal (whether or not
attached to a parachute) to be dropped from a small unmanned aircraft so as to
endanger persons or property.
(2) The person in charge of a small unmanned aircraft may only fly the aircraft if
reasonably satisfied that the flight can safely be made.
(3) The person in charge of a small unmanned aircraft must maintain direct,
unaided visual contact with the aircraft sufficient to monitor its flight path in
relation to other aircraft, persons, vehicles, vessels and structures for the
purpose of avoiding collisions.
(4) The person in charge of a small unmanned aircraft which has a mass of more
than 7kg excluding its fuel but including any articles or equipment installed in or
attached to the aircraft at the commencement of its flight, must not fly the
aircraft:
(a) in Class A, C, D or E airspace unless the permission of the appropriate air
traffic control unit has been obtained;
(b) within an aerodrome traffic zone during the notified hours of watch of the
air traffic control unit (if any) at that aerodrome unless the permission of
any such air traffic control unit has been obtained;
or
(c) at a height of more than 400 feet above the surface unless it is flying in
airspace described in sub-paragraph (a) or (b) and in accordance with the
requirements for that airspace.
(5) The person in charge of a small unmanned aircraft must not fly the aircraft for
the purposes of commercial operations except in accordance with a permission granted by
the CAA.
Article 95 - small unmanned surveillance aircraft
(1) The person in charge of a small unmanned surveillance aircraft must not fly the
aircraft in any of the circumstances described in paragraph (2) except in
accordance with a permission issued by the CAA.
(2) The circumstances referred to in paragraph (1) are:
(a) over or within 150 metres of any congested area;
(b) over or within 150 metres of an organised open-air assembly of more than
1,000 persons;
(c) within 50 metres of any vessel, vehicle or structure which is not under the
control of the person in charge of the aircraft;
or
(d) subject to paragraphs (3) and (4), within 50 metres of any person.
(3) Subject to paragraph (4), during take-off or landing, a small unmanned
surveillance aircraft must not be flown within 30 metres of any person.
(4) Paragraphs (2)(d) and (3) do not apply to the person in charge of the small
unmanned surveillance aircraft or a person under the control of the person in
charge of the aircraft.
(5) In this article 'a small unmanned surveillance aircraft' means a small unmanned
aircraft which is equipped to undertake any form of surveillance or data
acquisition.
Article 2 and Schedule 1 - Definition of terms
Commercial operation
For the purposes of the Air Navigation Order 2016, "commercial operation" means any operation of an aircraft other than for public transport -
(a) which is available to the public; or
(b) which, when not made available to the public, is performed under a contract between an operator and a customer, where the latter has no control over the operator, in return for remuneration or other valuable consideration
Small unmanned aircraft
means any unmanned aircraft, other than a balloon or a kite, having a mass of not more than 20kg without its fuel but including any articles or equipment installed in or attached to the aircraft at the commencement of its flight.
What is a congested area?
The Air Navigation Order defines a congested area as being 'any area of a city, town or settlement which is substantially used for residential, industrial, commercial or recreational purposes'. |
