Galchanto
Flight distance : 101066 ft
Hi CHEUCKLATE,
Your calculation above is correct but unfortunately, your initial figure for velocity is wrong. I think you need to input the highest potential energy the drone has in flight which is 13.89m/s (50KPH) not 3m/s. If you do this you should get a figure closer to 29J which makes more sense and is below the regs in Croatia. The Mavic would top out at 121J which would indeed fall into the regulations.
Hope that Helps. |
