Oglo
Flight distance : 181693 ft
I don't have any of these problems on a HTC. Sorry to hear about all of yours. Maybe you are already doing it, but I do the following -
# Check that your USB connectors are absolutely in good condition.
# Look for interference sources near you i.e. cell towers & high voltage power lines.
# In Android control panel(settings), go to battery settings and turn on battery optimisation of all apps, this is designed to extend battery by killing background apps starting up, optimising/killing them. Optimise all apps, but then un-optimise DJI GO. It has the advantage of killing unnecessary background apps starting up while you are flying. You only have to do this once, checking occasionally that new apps or updates haven't changed this setting.
Before each flight session:
# Always run in airplane mode. Explicitly turn off WiFi & cell data as well.
# In Android control panel go to Storage, select the internal storage, and clean/delete cache.
# Get an App task killer like AVG, always kill as many/all apps before starting DJI Go.(make sure you don't set off a scan while doing this)
# Close every open App.(this is different to killing apps)
# Turn on GPS after doing above.
# once your phone is clean of other apps and empty cache, start up RC then DJI GO.
Good luck
