Do You Use Return to Home or Do You Manually Land
892558 892558 2017-6-7
Clare_G101
Flight distance : 39236 ft
Just wondering what other people do, I personally always manually since I usually fly when I can always see my drone/know where it is and I always feel more comfortable manually landing it
Single SelectVote, Total 605 people participate in voting
Distance end of: 29871 Day8 Hour1 Min
Your user group with no voting privileges
2017-6-7
Bent Kangaroo
Flight distance : 362510 ft
Catch land for me.
Pull the Mavic into about head height and approach from the side and grab the undercarraige and pull down on the left stick.
The blades will thank you for it and it can decrease risk of getting contaminants (sand/dirt etc) in motors.
So i voted #3
2017-6-7
Ron in Utah
Flight distance : 10902 ft
Manual landing. I have several hours of experience flying DIY quadcopter in "atti" mode and can fly pretty good LOS. With full GPS positioning it is almost too easy. That said, I do plan to test RTH at some point, but the last time I tried it, the Go 4 app crashed right when I pressed the RTH button on the remote.
2017-6-7
Lucas775
Flight distance : 50642090 ft
I RTH when in a clean surroundings and hand catch when in a sketchy place.
2017-6-7
VMav
Flight distance : 76814 ft
I like flying (though recent DJI offerings are for aerophoto/video work mostly).  So, I voted #2
2017-6-7
Iamz
Flight distance : 487480 ft
Thailand
Both. I use RTH to start the return trip and monitor the video feed, telemetries, and look at it to make sure there's nothing close by. Once it's about to descend, I take over and land manually.
2017-6-7
StephenGSY
Flight distance : 814232 ft
Guernsey
Normally RTH because I’m lazy. But always keep an eye on it. Had the odd occasion I’ve had no choice to manually land due to Compass error or something else that prevented a safe RTH.
It’s worth noting that these pilots who insist on going beyond VLS and behind obstacles will fall foul of an automatic Atti mode switch one day.
2017-6-7
Maveriksam
Flight distance : 417500 ft
I always land manually. Two reasons for this.
1. Giving full control to the Mavic scares the hell out of me.
2. Even though I've set my return altitude to 40 meters, I'm still concerned it won't be high enough. (We don't have tall trees where I live)
Quick question.
When I set the RTH altitude am I correct in saying I am at zero?
If this is the case, If I then increase my altitude to fly up hill, when I press RTH will it then descend into the hill on return or will it stay at that altitude all the way home?
I hope I've explained that properly.
Thank you
2017-6-7
Jenee 2
Flight distance : 7852129 ft
I can land and takeoff manually but use auto takeoff and RTH. I figured I paid for a drone with this technology and I am going to use it.
2017-6-7
Bay Cruiser
Flight distance : 2039288 ft
Jenee 2 Posted at 2017-6-7 21:48
Me the same, I always flew my phantom back and hand catched but with the Mavic I use rth and auto land. Only done about 50 and so far all good.
2017-6-7
UCBarkeeper
Flight distance : 616982 ft
Switzerland
Maveriksam Posted at 2017-6-7 20:39
the mavic won't descend on rth, if the mavic is above the RTH altitude, it will stay on that level.
2017-6-8
afisch
Flight distance : 353146 ft
Switzerland
A litte bit of both, but normally i use RTH but always watch the mavic and have the finger ready to press pause and be ready take over the controls.
2017-6-8
Eagle_Eye
Flight distance : 4137720 ft
afisch Posted at 2017-6-8 00:54
+1....same here, finger on sport mode just in case.
2017-6-8
rydfree41
Flight distance : 153268 ft
Eagle_Eye Posted at 2017-6-8 03:31
I've generally only used RTH as a test over my 7 years of flying multi-rotors but the Mavic is steadily making me a lazy lander . It's cool to see the Mavic precision land within millimeters of where it took off from , often down to the exact footprint of its landing skids .  I do keep a close eye on the telemetry though.
2017-6-8
Eagle_Eye
Here's a vid I made recently doing a RTH w/ Precision Landing @ 85m high (RTH set Alt).
2017-6-8
Buzzyone
Flight distance : 4647913 ft
Mostly manual, with hand catch out in the country. Sometimes use RTH if I just want to fly it back and while it's doing that, busy myself packing up my stuff, taking control when I'm finished, for the landing.
2017-6-8
WolfgangStiller
Flight distance : 599416 ft
In many cases, automated landing (as from RTH) would risk damage since I take off and land in rugged terrain with no good landing spot.  In that situation,  I have no choice but to hand catch.
2017-6-8
Landbo
Flight distance : 502792 ft
Denmark
Yes at the place where the "lovely lady" says your home point is located, the height is always 0 meters on the point. Then you just put the RTH height larger than houses, trees, hills / mountains around you. My RTH height is typically set to 40 meters, so I'm sure my Mavic does not hit anything around here in RTH mode where I fly.
If you do not use RTH, you will never learn to use the function. Remember, you can always interrupt the RTH with the cansel button on the controller. Personally, I let my Mavic fly home by itself  in 95% of all my landings. I have never been afraid of the function since it works every time.
Mavic will:
1. Increase to the RTH height if the flight height < than the RTH height you have set and land vertically at home point .
2. Flying home to home point at the flight height it has when the flight height is > than the RTH height set and land vertically at home point.
Hope my miserable English helps you. Leif.
2017-6-8
Maveriksam
UCBarkeeper Posted at 2017-6-8 00:42
Thank you.
I may try RtH one day
2017-6-8
Mcflying
Flight distance : 243753 ft
I want every minute of battery juice use for flying myself.
2017-6-8
FPVJunkie
Flight distance : 66421 ft
I have yet to use RTH or Auto-Takeoff... I should probably test them out, but need to go to a wide open space. I of course prefer to do everything manually, but it'll be a nice comfort that it works if I ever actually need it.
I tried out the Hangar360 App to take a 360deg photo and it was very nerve racking giving the app full control over the Mavic for ~5 mins... lol. I've also used Litchi to set up a 10 min Waypoint flight and definitely needed a drink once it returned, although I could see it 95% of the time. I had looked down at my phone at one point when it was at the furthest distance and when I looked back for it, I couldn't find it.
2017-6-8
Jenee 2
Eagle_Eye Posted at 2017-6-8 04:00
RTH Precision Landing
Yes, pretty amazing. As I usually fly off grass and it is wet of a morning I always want to takeoff and land on a landing pad and the Mavic has always landed right on the spot, far more accurate than I can get. Never seen it more than about an inch out.
2017-6-8
DwoneFlyer
Sweden
I tried RTH once but clicked RTNT (return to nearest tree) by accident, worked well. i call user error on that one - lol {:4_181:}
now where did i put the manual !
2017-6-9
Griffith
Flight distance : 98537 ft
Iamz Posted at 2017-6-7 20:07
Ditto
2017-6-9
fans84c15d2d
Flight distance : 329154 ft
New Zealand
I prefer to fly it rather than press a button. More fun for me. However i do check that it works once in a while.
2017-6-9
fans8e7a06e5
Flight distance : 122831 ft
Auto takeoff then manual landing with hand catch from time to time.
2017-6-9
CharlieFliesDro
Flight distance : 36148 ft
99% RTH very rarely land manual
2017-6-9
spoonlamp_
Flight distance : 301506 ft
Romania
I always hit RTH initially and get it on the way, but will switch to manual once it starts the descent - it's just too slow. Also I've been hand launching and catching all the time lately.
2017-6-9
Mikko_blu
Flight distance : 12224 ft
manually land
2017-6-10
R&L Aerial
Flight distance : 298100 ft
I don't really trust RTH
2017-6-10
Nephroghost
Flight distance : 200456 ft
Had my Mavic a week- flown daily and still haven't used RTH.  Manual landing for me.
2017-6-15
fansc73d3cec
Flight distance : 33570 ft
Had my mavic 6 months now and never used rth. I have to give it a try but havnt yet
2017-6-15
M Power
South Korea
RTH is providing comfort to beginner...but wehn i'get accustomed to mavic..manual seems like more natural and feels safe to me.
2017-6-15
Ray_Dunakin
I only used RTH once, just to see how well it worked. Generally I just prefer to land it myself.
2017-6-15
cristianc
Flight distance : 1008143 ft
Land it myself, if the landing area is unsuitable I will hand catch it.
2017-6-16
Glenn Goodlett
Flight distance : 27978153 ft
The only time I land manually is when I'm low on battery and bring it in nose first and land at my feet quickly.
2017-6-16
Broken Deviant
Flight distance : 176919 ft
I have used both but most of the time I do Manual landing. Most of my flights are from my front yard and with my lot full of trees, I have to keep a close eye on it.
2017-6-16
Mari
Flight distance : 1308780 ft
Manual take-off and landing... last time low battery and MP started RTH by itself...
2017-6-16
Maxi3D
Flight distance : 307621 ft
I fly my copters, not the other ways around. Damn it, Jim! I am a pilot, not a button pusher.
2017-6-16
Bradders
Flight distance : 862283 ft
I personally fly home and fly it, watched a youtube video the other day and apparently a tip for using RTH is when you take off ascend to 20 or so feet and hover there for 5 seconds, the Mavic will take a picture below it and when you press RTH next time it will remember the exact location it took off from, and if you use one of these http://amzn.to/2tpDrsj it differentiates the surrounding area to the take off spot and will allow the Mavic to return to home point more accurately.
2017-6-20
