New Firmware V 01.04.0602
123Next >
14814 109 2017-6-7
Sebi
Flight distance : 5089226 ft
Poland
What’s New?
- Updated No-Fly Zone Management.
- Optimized No-Fly Zone Return to Home.
- To ensure safety, flight will be limited to 30 m height and 50 m distance if you’re not connected or logged into to the DJI GO 4 app during flight.
- Optimized gimbal performance to improve its stability during flight.
Notes:
Make sure to upgrade both the aircraft and remote controller to the latest firmware, otherwise video downlink may be unstable.
2017-6-7
BrianKushner
Flight distance : 41420253 ft
The first casualty for me is loss of the Smart RTH Setting under the battery settings. I lost it in the beta and it never returned...
2017-6-7
SM-17
Flight distance : 179288 ft
Malta
Shall the ones that used the beta update again?
2017-6-7
Helimage
Flight distance : 144140 ft
Finland
Had to relink the RC to get live video feed back, everything should work now. Test flight soon.
2017-6-8
FamilyFrames
Flight distance : 1612283 ft
Russia
after updating of the panel on phantom 4 pro + at inclusion writes that the library of the downloaded cards is lost how to restore it?
after updating of a kopter and the panel there is no communication and and the black screen on phantom 4pro +
2017-6-8
Snowwolfwarrior
Flight distance : 1064780 ft
Taking much longer to update than normal. been sitting at 99% for 12 minutes and also asked me to disconnect and re connect data cable ? I have now disconnected from ipad and now trying to update through DJI assistant 2Just an update, I updated through Assistant 2 and it showed to update ok but the remote/go4 app would not see the P4P I had to re link them both and now all ok, never had this happen before?
2017-6-8
hdlou94
Flight distance : 753163 ft
I have received many notices when i turn on my remote and app. but I have not yet updated
2017-6-8
JAFARINI
Flight distance : 15252589 ft
Georgia
Snowwolfwarrior Posted at 2017-6-8 00:57
Same here! Stuck on 99%
2017-6-8
Snowwolfwarrior
JAFARINI Posted at 2017-6-8 01:47
Have you tried updating via Assistant 2 ?
2017-6-8
JAFARINI
Georgia
Snowwolfwarrior Posted at 2017-6-8 01:55
No I don't have Admin rights on PC cannot install Assistant 2
2017-6-8
Snowwolfwarrior
JAFARINI Posted at 2017-6-8 02:02
Is it not your pc ? looks like the only way you can sort this is via assistant 2
2017-6-8
JAFARINI
Georgia
Snowwolfwarrior Posted at 2017-6-8 03:03
I tried re-linking RC and aircraft and after some time it managed to get to 100%.
Very strange and seems it needs to be fixed by DJI !
2017-6-8
mikeon
"- To ensure safety, flight will be limited to 30 m height and 50 m distance if you’re not connected or logged into to the DJI GO 4 app during flight."
Where does that leave Litchi users?
2017-6-8
taurus35
Flight distance : 136417 ft
mikeon Posted at 2017-6-8 03:55
That's what I was wondering, or any third party app for that matter.....Auto Pilot, DronePan, Hangar360 etc
2017-6-8
theGrindLab.com
Flight distance : 1375846 ft
That's my question too!
2017-6-8
Flight1989
Flight distance : 7825 ft
Russia
Same garbage, update via smartphone 99% camera hangs and nothing happens...now after connecting the copter to the remote, there was no picture says NO SIGNAL....what to do?
2017-6-8
Punchbuggy
Flight distance : 483166 ft
Litchi needs to be updated using DJI SDK 4.1. to bring in line. I'm not sure whether they've done that yet. One way to find out...
2017-6-8
Punchbuggy
SM-17 Posted at 2017-6-7 23:33
Yes. Beta was dated April (I think) and was v1.04.0510. In theory, this prod firmware has other updates beyond the horizon fix (but sadly no doubt just to enforce No-Fly zones).
2017-6-8
Punchbuggy
Just a note that I've successfully updated - but not without drama. I first updated the craft, but then it no longer connected with the RC - both link LEDs red. Did a forced re-sync (C1+C2+Record and P4P link button). All good, but link LED on the RC was rapidly now flashing red/green. GO on phone told me there was an RC update (the release notes also mentions it). Updated RC. Lost connection again. Did a forced re-sync again. All good.
Tried to run VPS calibration - "Frame Alignment Error" persists. Downgraded to Assistant 2 v1.1.1 - same. Downgraded to v1.1.0. All good.
Phew. I live to fly another day. Yay. Heading into country for the weekend to test out, alongside my DJI-neglected but trusty P4.
[Edit] As noted by others, the DJI GO app seems to be returned to factory settings, and so I'd definitely be assuming craft setting set to default also i.e. do a VPS calibration and a Gimbal calibration. Otherwise, if you didn't have errors with Assistant 2 prior to the upgrade, you may not have to downgrade versions like I did. BTW, Assistant 2 v1.1.2 is available under the Spark download page, although that's probably only adding Spark dialogue...
2017-6-8
Snowwolfwarrior
Flight1989 Posted at 2017-6-8 04:51
Read above posts on what to do
2017-6-8
FamilyFrames
Russia
There was a picture after updating!)
1. Full dumping of factory settings on the panel and dji, I have P4p +
2. to reconnect the panel with a kopter
2017-6-8
FiShBuRn
Flight distance : 4633533 ft
Portugal
Its mandatory to do all calibration after the update?
2017-6-8
GoodmanRP
Flight distance : 4344974 ft
Poland
After updating does not work for me! There is no connection with the RC! Why?
2017-6-8
Sebi
Poland
2017-6-8
CanonMax
Flight distance : 8953215 ft
re-link your Remote Control with your Aircraft... easy to do
Regards,
Max
as per: 2017-06-08:
DJI Phantom 4 Pro Model WM331A - Serial: 0AXDDCC - 0A20814 (January 8th 2017) flying in MODE 2
Aircraft Firmware: V 01.04.0602 (June 8th 2017)
Phantom 4 Pro Remote Controller (GL300F) Firmware: V 1.4.1.0 (June 8th 2017)
DJI GO 4 App iOS: V 4.1.0 (May 26th 2017)
DJI GS Pro App: V 1.2.1 (March 28th 2017)
Flight Database V. 00.00.01.04 (1April 12th 2017)
App Database V. 00.00.01.04 (April 12th 2017)
Apple iPad Pro 9.7" 128GB iOS 10.3.2 (1May 16th 2017)
Litchi App: V 1.16.2 (May 24th 2017)
Litchi Magic Leash App: V. 1.0.3 (April 14th 2016)
Litchi Vue App: v 1.0.1 (October 15th 2016)
Hover App: V 2.3.0 (March 13th 2017)
Airmap for Drones App: V 1.3.2 (March 16th 2017)
GPS Plan App: V 2.5.1 (August 30th 2016)
H.D. Sync App (Healthy Drones.com/AirData UAV): V 1.1.0 (March 23rd 2017)
2017-6-8
CanonMax
I followed all instructions op my iPad (even disconnecting - re-connecting) and everything went perfect... Remote Control, Aircraft (Phantom 4 Pro) and all batteries updated without problem. Of course that takes some time...
Kindest regards,
Max
as per: 2017-06-08:
2017-6-8
CanonMax
FiShBuRn Posted at 2017-6-8 06:21
This is always a wise thing...
Regards,
Max
as per: 2017-06-08:
2017-6-8
mikesher.live
Flight distance : 123045 ft
taurus35 Posted at 2017-6-8 03:59
Thats one of my concerns as well.  The other is the need to fly where there is no cell service to log-into DJI.  I think DJI really screwed the pooch on this update.
2017-6-8
trance728-
Flight distance : 298048 ft
Hey CanonMax
Ever think about removing all that crap from your signature, all of your posts are stupid long for no reason.
2017-6-8
trance728-
Does the flight limitation they mention about not being connected just refer to being signed in initially to the app and doesn't meant you need internet while you fly?
So in the P4P+ I never have internet, does that mean I'm fine as long as I was logged into the app the last time I was connected to the internet?
2017-6-8
DJI-Mark
GoodmanRP Posted at 2017-6-8 06:26
Please make sure that you update the RC when completing a Firmware update. Also, please make sure you are hooked up to a Wi Fi when completing this process.
2017-6-8
GoodmanRP
Poland
DJI-Mark Posted at 2017-6-8 06:57
Thank you for the reply!  Refreshed software by DJI Assistant 2.  Update new again. "No signal" need to "Linking the RC"
2017-6-8
CanonMax
trance728- Posted at 2017-6-8 06:57
Hey CanonMax
Sure I thought about it, but in this way interested people will know the exact details... I often read "lastest firmware" but I discovered that this did not mean the VERY latest...
You do not need to read it of course!
On the other hand (btw it is NOT a signature, I do update this information) various people could ask me something about other apps etc. and they know NOT to ask me information about Android... etc.
Sincerely,
Max
2017-6-8
Antonio76
Flight distance : 144403 ft
Denmark
CanonMax Posted at 2017-6-8 07:46
Thanks CanonMax, I for one appreciate it
2017-6-8
trance728-
It looked like a signature because it's was posted in the same way on all 3 of your replies after your name.
2017-6-8
TTM
Flight distance : 81253 ft
Finland
I had also "No Signal" issue after updating drone firmware, but it's fixed with linking rc again. Now drone works fine and camera horizon issue is also fixed. Thanks DJI.
2017-6-8
DJI-Mark
Glad your situation is resolved. Happy and safe flying to  you. Take some great photos.
2017-6-8
theGrindLab.com
I appreciate it too!
2017-6-8
Snowwolfwarrior
Too windy here to try out new update, I do hope it has cured the tilted horizon issue
2017-6-8
Antonio76
Denmark
CanonMax Posted at 2017-6-8 06:46
Regards,
Just did the updates, through the DJI GO4 App on an iPad 5th gen, all went smoothly, just had to relink Craft and RC to clear the no video downlink issue.  BTW, in your post you say "Aircraft Firmware: V 01.03.0602 (June 8th 2017)", while it should be  Version 01.04.0602...
2017-6-8
123Next >
