SPIKE_151
Flight distance : 69767 ft
I also had problems after updating, updated via ipad to latest version aircraft, then update RC, switched on aircraft and noticed connection led on RC blinking very fast red green, and connection status on pro 4 showing, disconnected, connected, poor video, changing about once per second. I relinked RC and AC , and that made no difference. Went into dji assistant v 2, rolled back craft to previous, 1.509 from april, check operation, worked fine in lichi and go 4 , solid green link light and all seemed normal. Then tried updating AC with dji assistant 2 , to new version downloaded ok updated ok, switched on AC had same problem as before when updating with ipad. same symptoms. Tried relinking, did not fix , tried go 4 relink, and 3 button relink, both had no effect with same symptoms as before. Then rolled back to 1.509 and drone works properly and lined to rc no problem. Do DJI actually have anything to say about this problem? Have update all previous versions with no problem on both AC and RC. I will be running previous version 1.509 with litchi until DJI give some definitive answer to what this problem is. DJI Mark can you comment please |
