MAVIC NEW FIRWARE 01.03.0800
1234
15387 131 2017-6-8
fansf1b690b6
Philippines
Anyone here experience extreme video live feed lag after updating to the latest firmware? Recorded video on the SD is fine. Im using ipad mini 4.
2017-6-17
RCNJ
Flight distance : 114665 ft
fansf1b690b6 Posted at 2017-6-17 14:55
Yes I had that once, switching to airplane mode and "normal" or HD for transmission seemed to fix it...hope it helps.
2017-6-17
larsvonhierblau
Flight distance : 95138 ft
Japan
AACY Posted at 2017-6-8 08:39
Yes they did increase, but is just that they included the approach and departure patterns of each runway, which before where only in as a warning zone, not a mayor deal breaker personally. In the added pictures you can see the difference between the both NFZ.
Well thats not entirely correct. The 30 Meter altitude limit is now removed. See on the old NFZ the bright half transparent red circle got removed. Now its either 120 altitude or no fly within the NFZ . I could fly before with getting some nice shots at 30 meter high ;)
2017-6-19
W.T. Foxtrot
Flight distance : 1316732 ft
I have had that as well -- unfortunately airplane mode did not fully correct mine.  Also having a lot of disconnects/interference/etc despite the fact that the drone is literally 10 feet away from me.
Disappointed in this and the latest release of DJI GO4 as the Editor portion is basically unusable on my brand new iPad Mini
2017-6-19
fanse9c47f56
Brazil
Hello people! I recently bought a MAVIC. I'm trying to install the DJI GO App, but I'm not successful. The app that installs is DJIgo4. Is that correct? Because, the system is not recognized. If someone can help! Success for all!
2017-6-19
fanse9c47f56
Brazil
2017-6-19
Car147
Flight distance : 180351 ft
Finally got a decent flight in today after the weather improving, only difference i can find is the controls seem a bit more sluggish in GPS mode, ended up buzzing around in sport..
2017-6-19
Jamison74
Flight distance : 4255778 ft
fans8b49495e Posted at 2017-6-8 04:49
It is not, unless you want new features, improvements, not available in .400
I guess, you will still have to update the Go4 app to 4.1.0 soon, as DJI would force you to do it, making previous versions not working. Somebody wrote, this should happen in a month.
Still there is a screenshot after latest FW update, stating that you can downgrade from .800 even with latest GO4 app.
I am using the DJI Goggles with full functionality on few .200. As others stated about the past Phantom series and the Mavic, I experienced loss of range after an update. I downgraded and have been happy ever since. I guess my point of view is, if your happy with your unit why risk it?
2017-6-21
Steveliu0418
I met a problem after the update, the pictures i shot in portrait mode all have a weird green line in it, but in landscape mode there is nothing...does anyone have the same problem?
2017-6-21
fanscbe312e7
Flight distance : 306722 ft
a_makarovsky Posted at 2017-6-8 06:53
Can anyone, who have already updated, confirm, whether the downgrade to .400 is still available?
The lowest I saw today was 0550.  Didn't see .0400 as an option to downgrade.
2017-6-21
AACY
Flight distance : 518012 ft
larsvonhierblau Posted at 2017-6-19 00:29
Great clarification, thanks for it! I haven't flown near any NFZ area before, so I could not tell the exact behavior of the AC before and now. But thanks for bringing this up, now we know better what to expect in the case of...
2017-6-21
larsvonhierblau
China
You're welcome. Actually not much dramatic happens near an nfz. Tricky is just that if you are on the edge of an nfz the drone likes to have a jumpy gps signal, which results in sometimes the drone wants to auto land
2017-6-26
1234
