MrDave
Flight distance : 1159331 ft
I updated my Phantom 4 Pro, and the Remote controller today. I performed the Compass calibration and as the IMU no longer has a manual calibration setting, that was not performed.
I went for a test flight, 400 feet high and 3000 feet out and all was well, video capture and still photo capture with and without the mechanical shutter was fine, everything seemed great!!! So I ran it around the neighborhood, out upwards of 1/2 mile, a bunch of times and when I got down to low battery's first warning, somewhere, like 8 minutes or so, I flew home and then proceeded to fly around the driveway and the yard in "P" mode. That's when it happened. I was testing the forward object sensor and when I got near my METAL car I got a warning popup that my compass was out of calibration and to take it out of "P" mode. Remember, now, I had performed the compass calibration on a wooden surface away from any metal objects and my remote control and phone were 10 feet away, as well, right before this flight. The message began to scroll across the top of the display where it shows your aircraft has been connected, as a warning. I started to move my drone a little bit and that's when it happened. My Drone was still in "P" mode while displaying that I have a compass calibration error and WHAM, it started moving on it's own and before I could attempt fighting the runaway drone it flew itself into my front porch railings and broke a propeller and dropped into an azalea bush, about 2 feet down.
Here is my question... Has anyone else noticed that things like a car within a couple of feet of your drone causes a compass calibration error, or was this just a one off on me and I should forget about it?
This is the first time, ever, that my P4Pro has had a run away event, and it happened 10 feet away from me. There is no way that crash was my fault and I know it had everything to do with the compass calibration error, which appears to have been caused by being too near to my car after a full flight while it was in low battery warning mode, about 6 minutes or less of power remained when flying near my car caused a compass calibration error.
I hope if this is a bug in the new firmware that DJI fixes it quickly, as flying near metal objects is normal, at least for me, when you're in close proximity to your drone and have clear visual contact over the drone. And to have the drone fly out of control because you're in "P" mode and the erred compass tells the drone, hey you need to be 20 feet over there right now (or what ever it told my drone) I really don't think that is acceptable operation. |
