My 1st post, so forgive me if I've created a long post than normal!
A DJI Mavic Pro Battery issue. It seems this is a common issue, I have written to DJI Support with the same problem. The reply from them after the following Msg was to ask if the green light blink twice or three time per minute. In my situation, I get a single Blink every 15 Secs. My Msg to DJI is as follows: A DJI Mavic Pro Battery issue. Yesterday I assembled and set-up my new DJI Mavic drone. Initially, I had difficulties in updating the firmware, on the couple of time it took me to unsuccessfully down load it, the original battery at around 50%, started to have problems and would not turn off. It seemed to lockup with to two (2) centre LED on green and occasionally plinking of and back on to green. Eventually, my only option was to remove the battery whilst still on. I then replaced the battery with my spare one, and successfully down load, install and set-up the firmware. At this stage I was able to Stop, Start the drone at will and operate all the features. Overnight, I put the locked battery on the charger hoping it may discharge and recharge the battery. Unfortunately, that didn’t happen and now, after 24 hours plus, the battery is still showing the same two green LEDs and occasionally blinking. Has anyone else experience this situation and how can I rectify the problem without having to replace the $150 Battery.
