Drone with British Airways to Turkey
TheWhiteGuy
So, I will be travelling to Istanbul, Turkey next month with British Airways and only be using checked baggage. I was just curious whether or not I would only be able to carry my Drone along with me in my hand luggage especially since all the new restrictions which were put into place .
2017-6-10
DocAraxá
Flight distance : 202283 ft
Brazil
Dear WhiteGuy,
When you say new restrictions put into place, do you refer Istambul or British Airways?
The purpose of my question is that I intend to fly to Germany by British, via Madri; so it's important for me to know about restrictions on British airways.
Thanks.
DocAraxá
2017-6-21
TheWhiteGuy
DocAraxá Posted at 2017-6-21 04:44
Dear WhiteGuy,
I know Turkey in general has some restriction but the restriction put in place were generally for countries from UK and USA to a list of other countries such as Turkey,  I believe if you're flying from Germany you should be fine especially with it being Spain as well
2017-6-26
blackcrusader
Flight distance : 689774 ft
Taiwan
You had better research about drones laws in Turkey first.
2017-6-26
DocAraxá
Brazil
TheWhiteGuy Posted at 2017-6-26 15:15
Thank you very much!
2017-6-27
Gillega
I’ve recently traveled United (several times within U.S.) and sailed through TSA checkpoint without  questions. Note: I removed the battery and sent them via U.S. Mail. I also called United and they were very helpful in confirming regulation they’ve posted on their website. In General, no batteries in carry on. Batteries in check luggage’s must have contact points covered / taped and must not exceed the FAA required voltage. The FAA required voltage restriction may be a pain as you need to confirm your batteries capacity and calculate that based on the number of batteries you are taking with you. (Batteries was one of the Part 107 test question I had and thankfully I studied enough to be able to calculate).
In Phoenix, the TSA agents asked to see my drone but it was because of interest in the drone and not a safety concerns. So, I would contact the airlines as well as the country you plan to visit. I hope this helps
2017-6-27
dancopter
Flight distance : 17901030 ft
United Arab Emirates
Batteries should be fine as carry on. They're below 100 Wh, so under the applicable limit. This is one of the reasons the Inspire 2 has two batteries, so they are both under the limit.
My Phantom got swabbed for explosives once, but was soon on my way.
2017-7-1
