hallmark007
Flight distance : 9827923 ft
That noise your hearing sounds very much like Imu working overtime to keep everything on an even keel.
I know you said you did IMU a number of times, but it really needs to be done correctly, i.e. You need a very level surface use spirit level to check, make sure you get to the end of process.
Then check it at low height .
If you've done all this, and still have same problem, you may need to send in for analysis. |
