fans04f05fdd
Ok, first the details, I'm using 4k, 60fps, on a sandisk micro sd writing at 80mb/s.
i'm using an ipad mini 2, which is on the list of "recomended" tablets. its new, with no other apps on it.
I have the stock p4p setup.
Hi, I have a p2p, and i've flown about 6 hours on it total now. Everytime i fly the live view stutters and freezes, and goes green sometimes. its not constant, but it is enough that i can't fly anywhere close to objects unless i can physically see the drone and the distance between said object from the ground. Sometimes its so bad i can't even fly it at all.
This has happened in every resolution down to 1080. no change... stutters and freezes, while the recording on the sd card is fine.
it seems worse now after the update i did on 6-10-17.
i NEED to fix this as i am an aerial photographer and have jobs lined up. Is there a fix? or do i have to send it back?
please help. Thank you to anyone with advice.
