DJI Diana
Flight distance : 2408 ft
D-unbar Posted at 2017-7-25 21:28
Hello I am also having problems calibrating my phantom 4 . I am getting the same error code 13 . I have tried cold calibrating even using cold temperatures to calibrate but to no avail. What is the next step? Do I need to replace the imu? is there a calibration reset?
Is the firmware up to date? Upgrade the firmware, then try to calibrate the IMU for several times in different place, if it is still the same, I would recommend you send it in for diagnosis and repair. |
