Donnie *
Flight distance : 3636782 ft
Make sure you always update the Aircraft first . DO NOT UPDATE THE RC TRANSMITTER TILL YOU GET THE AC UPDATED You say that the FW update will not work on the AC is that correct . Read my tips page and see if it helps .
You have an Inspire with the X3 camera correct ? The reason I ask is that the FW will default to the X3 firmware, if you have the Pro version and the X5 camera Or other you MUST first pick the camera system before choosing the FW to load . Be sure to format the Sd card.
Read my tips page and see if you. can glean an solution there first .
http://forum.dji.com/thread-45630-1-1.html
donnie
