After the update, IOSD MARK II dead
2488 3 2015-3-13
hamid.ebrahimi6
Iran
hello dji ,
I've updated IOSD MARK II, and after the updates became completely destroyed.
Is the solution to repair it?
2015-3-13
knarfboy
Flight distance : 494508 ft
write a email to  support@dji.com
2015-3-22
DJI-Dave
Yes you will need to send it in.
2015-7-10
hamid.ebrahimi6
Hello
may be for you also happened , Failure IOSD mark II .
Failure :
1.Not connected to a PC (computer can not detect)
2.Video output is not
solution :
open the IOSD frame, After opening, RAM out of the slot and discard.
To do this you need a cutter , To remove the Glues Silicone.
You can replace the RAM 4 GB, 8 GB of RAM use.
Congratulations you've been able to Debugging.
And do not need to spend money to repair send.
http://forum.dji.com/thread-53961-1-1.html
2016-5-29
